Hi. I have a prebuilt hp system (my work-desk pc) with the following specs :
i7 8700K
Rtx 2080 {Card maker unknown}
2Tb HDD
Windows 10 pro
Nvidia driver : 441.20
No overclocking.
I ran the Unigine's superposition benchmark to stress test my GPU, however I noticed that the fans didn't kick in, even though the GPU reached temperatures as high as 84 degrees. I tried the same test by setting the auto fan-control on the MSI afterburner and noticed that the fans do run when the GPU crosses 60 degrees. Even at max load the temp reached a max of 72 degrees (I tested the system for 1.5 hrs). I turned off the MSI software to run the system on native settings and ran into the same issue again. Unfortunately i can't open my system to see what the problem is, as it would void my warranty (warranty sticker on top). I hope the psu connections to the GPU are fine ! Any help would be appreciated. Do let me know if you require some more info.
i7 8700K
2Tb HDD
Windows 10 pro
No overclocking.
