Question Ryzen 5 3600 and Cryorig H7 on Core V1 high temps, Cooler replacement ? Help !
Mazatan
75
Hello everyone, currently my build consists of a Gigabyte Aorus B450 mini itx + Ryzen 5 3600 on a Core V1 case, Im facing high temps with it 40-50ºc on idle and 80-85ºc while gaming. I reapplied thermal paste but no luck, same temps. Not sure if the 3600 its too much for the H7. I tried to undervolt or set a voltage limit to 1,27 @ 4.2ghz but the thermals didnt improved. I had a Ryzen 5 2600, same cooler, same case but idle at mid 30's and 60ºc while gaming. So Im thinking about other options (cooler) to improve my temps:
be quiet! Dark Rock Pro 4 . (will need a case mod)
Noctua NH-D15 (will need a case mod)
Arctic Freezer Xtreme Rev. 2
ARCTIC Freezer 33 eSports ONE
Does someone has any experience with any of the coolers above and a Ryzen 5 3600 ? , are any of them an improvement over the H7 ?
Thanks in advance
You are doing something wrong, or your case airflow sucks, for that cooler not to be enough for an R5 3600.
I was wondering the same, but I did check if the cooler was loose and not too tight, I havent changed the airflow on the case, its still just the front 200mm fan. I just replaced the CPU and that was it, same thermal paste brand and amount that I used on the 2600. Any thought on what might cause the high temps ?
