[SOLVED] Ryzen 5 3600x to hot!
Oct 15, 2020
7
I have a ryzen 5 3600x with the stock cooler and it has a idol of 60c and maxes up under heavy load at around 85c. Anything to help me out??? Also I believe it is on max boost. My motherboard is a prime b450M- A. Should I buy a after market cooler?
That sounds about normal. People on the internet are reporting similar temperatures for that processor with the stock cooler
Those temperatures won't destroy your CPU but a better cooler would prolong its lifespan longer. And would probably be quieter. Stock coolers are typically designed to be "good enough" and not much more due to cost reasons so I wouldn't expect much from them
Reactions: kurdtnz
It is worth reseating your cooler with fresh thermal paste to check that it is cooling properly.
You will get higher temps with it on max boost.
I find that PBO on Auto gives the best performance and temperatures on my 3700X with the stock cooler.
Andy
