Sapphire 7950 - 3 monitor issue! Help?
Shazma0527
43
I just built a beast machine, bought this specific card and having problems:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102962
Its the Sapphire 7950 - it has:
1 HDMI
2 Mini Display ports
1 DVI
I currently have my 3 monitors plugged into 1 DVI (converted cable) to Mini Display, 1 in DVI (converted cable) to HDMI port, and 1 DVI straight.
Both the Mini Display and the HDMI monitors are working fine - the DVI will not display anything unless I unplug the other 2. Please help!
Thanks!
Shazma0527
43
I'm not sure what that means between active and passive.. Please explain?
If you could point one out to me (don't care where, I need to get one asap) that would be helpful.. (Thank you for your assistance btw!)
