[SOLVED] Sapphire Radeon driver problem ?
StellaMan
50
Hi there, I hope someone can help me here ...
I have installed a Sapphire Radeon HD 7950 3GB GDDR5 PCI-E into my PC (Motherboard is a GA-970A-DS3P (CPU 1), PSU is 850 watt, running Windows 10 latest version) which appears to work perfectly OK, until I install a driver !!!
As soon as the Driver update is run and installed, I lose my display and just get the "No Signal" message on the screen. The PC is still running, I just have no display so can't do anything !!!
I can boot into Safe Mode OK and from there I can uninstall the Driver, reboot normally and the PC runs just fine until Windows Update runs again. If I disable WU the driver isn't installed and I can use the PC indefinitely and without problem, except, of course, I can't use the advanced capabilities of the GPU.
Any ideas please ?!?
