Hello everyone,
I've recently upgraded my PC and passed down some components to a family member, including my Asrock z390 Extreme4 motherboard. To enhance their experience, we replaced their old SATA drive with a new M.2 SSD. I've had positive experiences using an M.2 drive with this motherboard, so I anticipated a smooth transition.
We purchased this M.2 drive: . The Asrock z390 Extreme4 specs can be found here
The motherboard has a 1 x Ultra M.2 Socket (M2_1) that supports various M.2 modules, including PCIe up to Gen3 x4. The SSD we bought is Gen4, and from my understanding, it should be backward compatible, running at Gen3 speeds on this motherboard.
However, we're encountering an issue: the BIOS doesn't recognize the SSD when installed. I'm trying to determine if this is a compatibility issue or a fault with the SSD itself. Should I return this SSD and get a replacement, or opt for a different model, and if so, could you recommend one? We are looking for 1tb. Any insights or similar experiences would be greatly appreciated!
Thanks in advance for your help!
