[SOLVED] Some apps are blurred while others aren't. Help.
Bixmox
18
Some of the apps on windows are blurred for me for some reason, I use 125 scaling which is marked with (Recommended)
I am on a 1920x1080 laptop.
What can I do to fix this? I have tried the built in troubleshooter with no success.
Some apps which are blurred:
When I download something and it pops up with where it wants me to save it (literally file explorer) it is blurred, but the standard file explorer is not.
Some game launchers
Other apps which I can't remember
If I change the scaling to 100 other apps become blurred while the ones I have listed aren't
Thanks for any help/help attempts
Please change scaling back to 100%, then enter 125 as custom scaling under advanced scaling settings. Sign out and sign in, and the problem should be fixed.
Edit: You can try mactype to make fonts look a bit nicer.
Reactions: Bixmox
You are a legend, thanks!
Such a simple stupid fix, windows should have made it work themselves haha.
Reactions: mkaafy
