[watch your language]
earlier today i was using my pc, the case fans were quiet and controlled by msi afterburner, i tried out oc setting in the msi gaming app and it messed up my pc in an constant reboot where it tried to repair too but failed to do it. after that i had to flash the bios with flashback+ and the i got into windows. after that the case fans are controlled by msi afterburner to a degree since i can hear that the fans spin louder when i set the speed to 100. i can no longer control the fan speed manually an the bios and the lowest rpm is around 800. i have costume fan settings in afterburner that it should follow and smart fan control in bios dont work since the fans don't make less sound even though i use the settings i used before my pc got messed up.
