Hi rjbrunker,
Stingstang is absolutely correct, but if you want the website address, then I've put it below: http://support.creative.com/Downloads/searchdownloads.aspx?filename=SBXF_PCDRV_L11_2_18_0015A.exe
I realise that the website address looks like it's linking to an actual executable file, but it's just the search command.
Hope that helps - just make sure you select the right operating system.
Hi rjbrunker,
The link to download wont work. Plus its not showing up in my device manager.
If there are no Drivers installed then it should show up as WDM with errors in Device Manager, or X-Fi, otherwise, the card isn't being detected. In that case, try reseating the card or using a different slot
