[SOLVED] Storage does not look normal
So I bought a new power supply and hooked up everything incorrectly as I was using the original cables on the old power supply. This caused many problems. After I rectified this, I was able boot my system to find that I did not have any of my storage devices other than my M.2 drives shown on the windows explorer/disk management.
Some background on my drive config - I have 5 drives total - 3 of the 5 drives are SATA SSDs and the other 2 are M.2 SSDs. The 2nd M.2 is the newest addition that was installed during my power supply rework as mentioned above. 2 of the 3 SATA SSDs are in RAID 0 and I do not remember which port went to which on the motherboard prior to me changing my power supply.
My motherboard is an z370 Aorus Ultra Gaming WIFI -
SSDs:
970 Pro - 512
970 Evo Plus - 1TB (The new one)
2 x 860 Evo - 500 each (both in raid)
1 x 860 Evo - 500 - does not even show up on my system - nor in bios
Here is a picture of what I see on file explorer-
View: https://imgur.com/a/UQqHLle
Here is what I see on disk management-
View: https://imgur.com/1KSoKdp
So far I have swapped out the cables for all the SATA SSDs, I removed the M.2 that was just installed, I tried several combinations of the 2 drives that do show up on windows explorer/bios but to no avail. Each time including a healthy power cycle.
Any ideas? I'm not sure if I fried the last SSD but I think there's always the possibilities. I have also read that installing 2 M.2 SSDs will disable 2 of my SATA ports on the mobo - is this accurate to my case?
PS. I named the original drive Rootkit, it's not a virus... i promise.
That can easily be the cause of the missing drives.
You fried them.
Power off.
Disconnect ALL drives except for Disk 2, the C
Boot up
Does it boot correctly?
If so, connect each of the other drives, one by one.
See if they are recognized.
You fried them.
Power off.
Boot up
I think I am able to recover my 2 raid drives - looking into some recovery software, I was able to find about 700GB in the lost partition. These two can be recognized but they are not seen by windows as 1 combined partition, but instead 2 separate drives.
The next step I want to take is to recover the data, put it on the new M.2 ssd and then recreate the array on the 2 drives that lost their raid (in windows not bios).
Was this RAID 1 or RAID 0?
Can you show us the Partitions windows in DMDE?
https://dmde.com/
DMDE can assemble a virtual RAID.
This free tool can also autodetect the RAID parameters:
http://www.freeraidrecovery.com/
The damaged drives probably have shorted 5V TVS diodes or open e-fuses. In most cases there is an easy, no cost, DIY fix.
TVS Diode FAQ:
http://www.hddoracle.com/viewtopic.php?f=100&t=86
If you can upload photos of the damaged PCBs, I could show you what to do.
