I've been getting hard lock-ups (requiring power off-power on reset) in UT2k4, Far Cry, FEAR, and Rome:TW ever since I put this box together. I tested a bunch of stuff, but it turned out to be my sound hardware was causing the problem, both my Audigy and onboard (realtek ac97). If I disabled it I had no problems. Of course, I also had no sound.
I tried a 4-year-old driver I had from the machine the Audigy came out of. I had no problems, but the sound quality was terrible (screeches, twitters, etc.). I decided to try my onboard instead (it was disabled thru bios before). To my surprise, the problem is still there. Other stuff I've looked at:
I'm not overheating
My RAM is okay (tested once with each stick in by itself, in a different slot)
Hard drives are ok
PSU, at least according to the extreme load config, is okay
I *think* I have the latest drivers for everything.
I shuffled the audigy to all the pci slots
EDIT: I also played around with the hardware acceleration to no effect.
My specs, everything stock:
AMD 4800+ X2
450w Fortron Source PSU
4gb Corsair XMS
Biostar n4SLI-A9, has Realtek ac'97 audio onboard
WinXP SP2
Radeon x1900xtx, w/Catalyst 6.2
DX9c
I should add that this problem is partially predictable. UT2k4 gets it randomly, as does FEAR. Rome almost always locks up on the second turn, and I have a checkpoint save in Far Cry that produces the lockup within 3-4 minutes without fail.
Anybody know what the deal is?
I'm not overheating
Hard drives are ok
AMD 4800+ X2
4gb Corsair XMS
WinXP SP2
DX9c
