Suggest Power Supply for two GTX 560 ti's in SLI
gam0reily
336
Hello, :wahoo:
I wannna get a PSU to support my new build, with a gtx 560 ti, which I will SLI with another 560 ti in future.
As I can see from the geForce website, a single card needs minimum 500W power supply with two 6 pin connecters. I was looking at corsair PSUs but they only have 4 pin connectors. :??: I dont get it, how cud they not have power supplies with 6 pin connectors? :heink: Although it lists two PCI-E connectors. Is that the 6 pin connector?? :sarcastic:
Anyway
If not corsair, what brand and wattage should I go for getting a GTX 560 ti SLI? I think it has to have at least 50 amps on the +12V rail. So what do you all suggest??
Thx in Advance!! 😀
Hello gam0reily;
All the Corsairs have 6+2pin PCI-e connectors. You might have looked at one of the other PSU power leads.
To get the 4x PCI-e power leads you want you could go with:
CORSAIR Pro Series HX650 650W 52Amps +12V and 4x 6+2pin PCI-e power leads.
CORSAIR Enthusiast Series TX750 V2 750W 62Amps +12V and 4x 6+2pin PCI-e power leads.
Corsair has a special 15% off w/ promo code EMCNFJG23, ends 4/19
a 700w is recommended-
http://www.guru3d.com/article/geforce-gtx-560-ti-sli-review/14
GeForce GTX 560 Ti in 2-way SLI
A second card requires you to add another ~175 Watts. You need a 700+ Watt power supply unit if you use it in a high-end system (800+ to a KiloWatt is recommended if you plan on any overclocking).
i would suggest nzxt hale82 750w-
http://www.newegg.com/Product/Product.aspx?Item=N82E16817116015
it's SLi ready,modular and high quality(rebranded superflower i guess).for $90 it's a sweet deal.
A pair of 560ti will generate a lot of heating inside your case, so you will need a good air flow, thus it is recommended to get a modular, or a semi-modular PSU like:
CORSAIR Enthusiast Series TX750M 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Semi Modular http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
or
CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
How does a modular PSU use less cables to power the same hardware as a non-[strike]powered[/strike] modular PSU?
The cables that are not to be used by a modular PSU do no need to be in the case, while cables in a non modular PSU remains around blocking the air flow -- so a modular PSU uses less cables for the same amount of hardware.
That´s why I recommended the OP to get a CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=nwg7gvu06zbn
