Hello, first time posting here! I've ran into a little bit of a problem and I'm curious of the greater minds of the internet can help me out with this! I have a MSI Z390 MPG Gaming Plus mother board which is rather new! I have an iCue 4000X RGB case which I naturally filled out the case with 6 fans all 120mm : three in the front of the case and two at the top with one for rear exhaust. The fans I am using are ASIAHORSE WD-001 120mm 5V ARGB. The fans work and they all run with no issues, but I am not able to turn them up to max speed at all. The fans come with a fan controller that is powered through SATA power and then should be controllable through PWM in the BIOS or MSI Dragon Center. I have the PWM connector plugged into 'sys fan 1' and I have tried them all and it still in the bios its saying '0 RPM' aka not detected. On the other hand I've outfitted my girlfriends PC with the same fans, and same controller. She has 4 fans in her case opposed to my 6 so could this be a power issue with the motherboard or the controller? She has a MSI Z590 PRO WIFI and everything is configured and working. Fans are detected in BIOS and yet mine are not! (I have updated my BIOS to the latest version possible!)
