Question System stuttering
jtk459
22
About a week ago my speakers stopped working after I replaced them I noticed a weird audio stutter but it didn't bother me much I assumed it would go away when I restarted my PC but it didn't. It's gotten worse and worse now all audio and video stutters for 1-2 sec every 30sec - 2min at random intervals, today I noticed when it happens the mouse curser also stutters. I have done every fix I could find online for fixing audion stutter issues none of which have helped, I even reseated my ram and GPU. I've cleaned out any and all dust.
COMPUTER (I built it in Jan 2015)
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor
MOTHERBOARD: Asus RAMPAGE V EXTREME EATX LGA2011-3 Motherboard
MEMORY: G.Skill Ripjaws 4 series 32GB (8 x 4GB) DDR4-2666 Memory
STORAGE: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive,
Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
VIDEO CARD: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card
POWER SUPPLY: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply
OPERATING SYSTEM: Microsoft Windows 10 Professional SP1 OEM (64-bit)
What have you tried? So we're not repeating steps that were unfruitful for you.
A couple of things you can check,
1| What BIOS version are you on?
2| What version(not edition) of the OS are you working with?
3| Have you tried uninstalling and reinstalling your audio drivers in an elevated command, i.e, Right click installer>Run as Administrator?
4| PSU is as old as the entire system?
5| Akin to your audio drivers, use DDU to uninstall your GPU drivers, then manually reinstall said GPU driver with the latest sourced from Nvidia's support site.
1| American Megatrends Inc. 3801, 9/15/2017
2| 10.0.19044 Build 19044
3| Tried this already
4| yes
5| I don't know what DDU is but I have reinstalled the latest GPU driver
If this is your motherboard, since there are two other variants under the R5E moniker;
you have two more BIOS versions pending update.
Source(borrow) a donor reliably built PSU with at least 650W of power at the entire system's disposal. 7 years under those specs is a long time for a PSU, so it's possible that it's no longer outputting the power needed by the system. If the donor PSU doesn't change the issue it could be memory or a corrupt OS.
You will need to use DDU to uninstall and reinstall your GPU drivers.
