Hi!
This might be an easy one. I recently upgraded from a MSI GTX 1070 to a Zotac 2080 Super. When I made the switch, I'm getting what seems to be even worse performance in the form of lag spikes and stuttering. I believe it is a bottle neck on the CPU (Intel 6700k OC'd to 4.4 Ghz) however when monitoring CPU usage, it's around the 87%-95% usage mark with GPU usage around 55-60%. However the outcome is an avg of 55 FPS on games such as BF1 @ 1440p 144 hz with dips under 30 FPS.
From all the research I've done, a 6700k shouldn't be bottle-necking a 2080 super to the extent that I'm seeing. I'm also confused as to why the performance would be even worse than when I was running the 1070. I've included a screenshot of the monitor graphs running BF1.
While I think it's the CPU, I suspect something else might be going on since a quick checks shows other systems running 6700k and 2080 having much different performance at stock clock values (https://www.gpucheck.com/gpu/nvidia-geforce-rtx-2080/intel-core-i7-6700k-4-00ghz/ ). Comp Specs below. Any Ideas?
Couple other Tidbits - CPU temps with 4.4Ghz OC stable at 85 deg C. I tried going back to stock clock and wasn't able to identify an appreciable difference between stock clock (4Ghz) and OC (4.4). Witcher frames around 50-60 FPS as well, quick turns with mouse resulted in same stuttering and lag spikes down to sub 30FPS. Again, GPU usage stayed around 50-60%, while CPU was up at 85-90% but not pegged at 100%. Novabench (not sure how useful or reliable) shows GPU performance way down compared to other 2080s (I don't know how useful this is or if GPU benchmark tests are affected if a CPU bottleneck exists).
CPU - Intel 6700k OC'd to 4.4 Ghz
CPU Cooler - Hyper 212 EVO CPU Cooling Fan
GPU - Zotac 2080 Super 8 Gb
RAM - 16Gb Ballistix Sports DDR4 2400
Mobo - ASRock Z170 Extreme4
PSU - Seasonic 750W 80+ bronze
SSD - 500Gb Samsung EVO
Game Storage - 2 x 2 Tb 7200rpm barracuda
Monitor - ASUS ROG Swift 1440p 165Hz
