Hi!
I was running an asrock h110 btc+, HX1200w corsair psu, 4 gpus: 1x3080 ti (zotac) 1x1660s (asus strix) 1x5700XT(powercolor) 1x3080 (gainward FHR), 4gb ram vengance, running on win 10. Smooth, everything had been up for months.
Bought 1x2080 ti evga, 1x2080 ti zotac and had to upgrade PSU, bought 1 from a swedish shop:
https://swemining.se/produkter/huvudprodukter/mining-nataggregat-2000w-8-gpu
Plugged everything in and everything showed up without any issues. Applied OC´s and ran it. It ran for about 4-5 hrs, not sure since it was during the night. Rebooted itself and restarted miner. The thing is, the 5700 XT´s not showing up and the miner runs smoot without it. No heat issues before or after, no peaks in power draw. It totatls around 1060-1160w, have 16amps all around the house.
What ive tried so far:
Had it running today for 6hrs, nbminer restarted then rig shut down 3hrs later. It always turns on and runs as if nothing happened.
Any ideas? The only thing im thinking is something with psu...
pls be kind, englishs not my native language.
- checked every cable
- tried to just swap PCiE slot for that card
- installed hive instead
- tried to run the rig on lower OC´s, same thing
- Tried different power outlets, same thing
