Ruwed :
So is the water temp of 6c causing sweating because your ambient dew point is at that, or is it because of the temp difference on the CPU? I hadn't really factored in the dew point on the CPU as it heats up, I was just thinking ambient dew point...
Actually I do not even know what my dew point is, as I run an AC in my office even in the winter time, when the sun is directly on my office, and it is definitely run in the summer and it tends to lower my dew point to some degree, but I still do not know exactly what it is.
I know from my testing how low water temperature in the reservoir I can go without condensation building on the outside of the CPU water block, but you'll have to run your own tests.
Ruwed :
My dew point will allow to me go as low as -5c° comfortably some days (like today.. the dew point outside is -15c°, in my house it's probably around -4c°). I can't even give an average in my house, I've seen it as low as -8c° and as high as 6c°. But this is all ambient, so I'm ok on the hoses, but now you've got me thinking about the CPU itself sweating.
Where do you live to have these dew point numbers?
If those numbers are accurate you will be able to run a water coolant temperature much lower than I can, the CPU sweating is not the problem it is the copper base of the CPU water block over the size of the contact footprint of the CPUs heat spreader that is the main problem,
All my hoses or tubing is insulated so that's not the problem, like I said you'll have to run you own operational tests to see what happens.
Ruwed :
Have you by chance tested the flow rate on your modded CPU block? Do you know what the overall flow rate is for it? (Even a rough guess - It took XX seconds to fill a 1 gallon jug..)
No I have not run any flow tests past setting pump operation speed and checking for flow rate cooling improvements of the CPU but seeing as how the CPU water block itself is so efficient at transferring the cold to the CPU I just run on level 5.
The main reason being, it allows faster cold build up of the insulated reservoir, your insulated reservoir is your cold storage and where you build up the cold, from my experience the faster the flow rate the faster the cold build up in the reservoir.
Edit: Try not to over think everything you really do not need to know every exact detail of the chilled water cooling, (Unless of course you're OCD), all you really need to know is that it works!
After you conduct your own operational running tests under CPU (idle and load), you'll know what flow rates are best for your setup, and exactly how low of water temperature you can safely run and always be above and condensation problems.
You're in the learning phase now and no matter how much you think you've got it figured out, you will make changes as you learn what the cooling can do for you, and with your dew point range you'll get even further overclocking than I have.
I am of course assuming you're shooting for high CPU overclock goals in the 5+ghz range, if not?, there is absolutely no justifiable reason to even run this cooling.
