Question Temperature issue with Low Profile 1050 Ti ?
Aug 20, 2023
5
Hello
I have:
i7-3770
Motherboard H61H2 CM2
GTX 1050 TI Low Profile
8GB Ram 4x2 PC3 12800
AZZA 650W Power supply
And my problem is, i play Legends of Keeper and ok the temps are 40-45 no problem with this, but when i close the game my temps down normally but in a one point for example 38C no downs more MSI afterburner show 38C i reset the pc and ok the problem its solve but not its the most confortable solution xd.
I tried using DDU, other cable of hdmi, a DVI screen but the problem not solve with nothing :l I use this gpu in other pc (the vendor pc) for 4 hours and i verified the temps in all time and no have problems, but on my pc dont work i try every solution 🙁 pls help me i have this problem for one year
LumininCore IDDCX Adapter this adapter its a problem? i nothing view this in other of my graphics :c
I do not see a problem here.
Graphics cards can run hot, but they are designed to do so.
80c. is not out of line.
What is the make/model of your case?
Does it provide sufficient airflow to cool your parts?
Thanks for your responses
I understand your solves solutions, but i dont have 80c.
I have 38c. with no movement up or down. for example, when the graphics stay at 38c.
I play SnowRunner at maximun settings and temp stays at 38c.
normally my gtx in stock have 32C.
The problem is my temperature doesn't go up or down, it simply stays at one temperature. I reset the pc and it works fine. I don't have a gaming case, i have a simple case and I remove the left panel to play xd
yes i clean, and no, the cpu stay in normal temps (i have the stock fan but not pas 65C. in game)
but... Luminin Core i disable this and the temps no up top 30-60 instantly...
starts in snowrunner 39c. 45c. 50c. up gradualy but.. with the luminin core enabled simply open the game 60c. instant this driver its a problem?
I repeat, my issue is not that my GPU is at 80 degrees. I never said my GPU reaches that temperature; it only goes up to a maximum of 65 degrees. The problem I have is that when I play, the temperature reaches around 60 degrees, everything is perfect, and there's no issue. However, when I stop playing, the temperature gets stuck at, for example, 38 degrees. Even if I leave it like that for 5 hours, the GPU keeps showing 38 degrees. If I open any other demanding game, it still shows 38 degrees and doesn't change for anything in the world. Do you understand me now?
You mis- understand. I said that some graphics cards get hot, as hot as 80c, and that is ok.
So the fact that your card gets a bit warm should not give you concern.
I never said it was wrong for it to heat up, bro. But don't you understand that the card is at 38 degrees with a demanding game, a 1050ti with a demanding game at 70% usage, and the temperature stays steady at 38 degrees without it going up or down? Do you get it? I mean, understand that the temperature doesn't go down or up, and when I restart the PC, it drops to 33 and starts to rise and fall normally as it should. How can you tell me it's going to be at 38 degrees when it's at rest? And let's say, for example, playing something like Cyberpunk, I mean, the temperature doesn't budge in either direction. And I already said that my stock card is at 32-33 degrees, so 38-40 degrees at rest is impossible. How can you tell me that after 5 hours of not using it, the temperature won't fluctuate from 38 degrees? Come on!
I mean, the normal thing is that when you open a game, especially a demanding one, the temperature gradually rises, just like when you're cooking – the pan isn't preheated, obviously. The same thing happens here. If I'm playing a relatively demanding game, it should show temperatures like 38-40-45-50-55, and so on. But that's not happening. It just stays at 38, 38, 38. Even after 4 hours of gameplay, it's still at 38. I mean, if it were a 2D game, I could understand, but SnowRunner isn't a 2D game, haha.
