TH Water Cooling Club and Picture Gallery
Page 12 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
***UPDATE***
Finally got everything to add my second 7970. Added a second 240 rad, which took a little modding of the Arc Midi, but I think it turned out quite well. 😀
This one's a bit blurry, sorry:
Let me know what you think!
i liked two things the most in your entire setup:
1| the hanging res - might wanna share that idea with us via your build log :) or maybe how you did it
2| the fractal PSU - didn't know they made psu's. Nice design consideration.
Starting to plan an external radbox mod to add my cards into the loop,
2x Ex480's
16 Blue wings, What, MORE fans? 😛
2x 8 channel fan controllers, one maybe have temp sensors as well
and another x20 750L dual bay res/pump,
all living in a rad tunnel/box which will be bolted to the underside of my desk,
no partridge though, haven't figured a way to get the pear tree into the case,
Yet....
Moto
Wow that's some crazy WCing. You have such a creative mind, I would've never thought to put the res like that.
Very nice job sir. It looks really compact, too! 😀
I know I was in a hurry getting it buttoned up... EKoolant---> Blood Red...RS Kit. It is a hell of a lot better than a Corsair thats for sure..I will be cleaning up the cables shortly....6870's are vanilla...I have a very small computer budget..Plus I am only using a 550-watt Gold PSU so I didn't have much headroom for expansion from the current config
My current config uses right at 465 watts stock no OC...At 4.2 Ghz its around 495 watts so I do not have any juice left to expand..Its already crossfired and OCed
I bought the H100 and got the same temps as the H60/H50 rigs that I have...Temps with the Corsair units are as follows as per my logbook: H50/H60/ H100--965 BE @ 4.2 GHz -->1.53v idle: 26c , 100% load: 56c/57c/54c----> XSPC --- 965 BE @ 4.2 GHz ---> 1.53v idle: 26c , 100% load: 41c...I paid $125.00 for the H100 and the XSPC kit is only $129.99..So $4.00 for a 13c difference and it looks better too
price performance - win, XSPC kit
This is what I've been trying to tell people for ever...if you are spending that much on the H100, do yourself a favor and go with XSPC kit. If you are one of those people that have no idea how to actually use real watercooling, you still shouldn't be using a plug and play H100- you are better off getting a very good air cooler for 1/2 -1/3 the cost.
There are very few instances where I actually recommend a LCS cooler, and almost all of them start and end with real estate inside your case. Even then, you can find a good air cooler that fits the bill.
@rubix--->I was one of those people that didn't listen. I had to see it to believe it. Stupidity costs a lot, I am a firm believer now
@Lutfij--->Make sure to install the CPU block correctly on the RASA kit it comes with a lot of hardware you don't need and no instructions, I just guessed all the way through the installation, I used the wrong hardware to mount the block but I made it work, don't be like me install it right
I know, but it's to be expected. I am also skeptical when when I am new to something and have the urge to 'see for myself'. Often times I find out I was wrong and should have listened to experts to begin with.
I want that radiator..I did not have the funds to build the loop I wanted thats why I went with the RASA...Nice parts list all around...I took note of the attention to detail 🙂...I did buy an extra RASA kit but returned it as I couldn't use it.
well erm lets see how it comes along, would appreciate the extra feedback :)
* you've started so you'll notice that you'll want to up the ante with the rads, and maybe blocks :) i just wanted to get things right since they are shipping transatlantically and over the Indian ocean 😀
** might want to add the
tags and clean up that post.(without the spacing between the tags)
