TH Water Cooling Club and Picture Gallery
Page 11 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Lutfij - I was using a crappy point a shoot camera it's all i got 😛 but i'm sure i can do some better shots.
In regards to the Clamps being in Australia limits the Availability of some parts like those on short notice for now my stainless clamps will do till I can find a supplier here of nice looking ones.
I admit the loop doesn't look the best so far, but its working well without any restriction and still gives me access to all of my parts, loop might get re-arranged once i have GPU's and waterblocks. plus it gives me time to think it over.
:) oh you din't mention that you were from down under. Anyways - just be careful with worm clamps - i've read on most people tearing into the tubing and springing a leak and than cussing the tube manufacturers for their callous effort.
Plastic reusable clamps are another option as a cheap fix :)
Non-the-less , still a good loop there.
* what model/make cam are you using?
take these into consideration and input them in your cam -
go into options---> (set)
quality --> fine
color ---> vivid or normal
WB ---> set according to your room lighting(if its a lamp, set it to incandescent. Personally i like warm color WB'ing so i go for cloudy when i take some(not all)of my pics.
ISO ---> keep it on 100(your cam can go to 400 max, not bad for a cam of that price.)
metering ---> average
and last but the least, set it to timer mode. and before doing that - set it on a tripod.
let us see what you've come up with :)
Hopefully these are better shots
Yes i did some BF3 then sleep
So far after some testing I am not happy with it, temps are too high (even though that drop crazy fast off load)
I think my tubing config is restrictive so i plan to redo it.
the pics turned out better than last time. if you have a table lamp - aim it at the innards and than take a pic with the flash set to OFF.
i like the dark shot. If you do what i mentioned you'll end up with this:
only with more of your case being shown ... :)
** yeah once you rearrange the tubing in your loop - it'll look much better.
I doubt you'll see much improvement until you get rid of the nb block, thats going to be killing your flow
if you noticed the NB is actually a full cover MB block - so to take that out would rule out cooling the entire board.
though i am curious - what you use to fill your loop? distilled or premix
As long as his flow is .75gpm~1.0gpm, should be fine. They are restrictive, but I don't think they'd choke it to the point a huge performance hit. I'm not a huge fan of chipset blocks on an average budget build (secondary pump would help).
You could potentially run a parallel split between the blocks and then merge them after. This might counter the flow-rate and pressure drop you'd encounter if you ran them serial like that. Same concept people use when running parallel GPU blocks.
I like this. Maybe run a small parallel tube (as opposed to a 1/2" ID) so you don't completely drop the mobo block's flow right off the chart though lol.
Yeah, you could go to a 3/8"ID split (for example). Either way, this is a good work-around when you are considering multiple, higher-restriction blocks.
This is a concept that I'm reading more about recently and while I still think serial is the best option in most instances, there are some benefits to parallel splits when restriction is concerned. Your flow drops by 1/2, but your restriction is 1/4 vs what it would be in serial since your flow is split simultaneously, instead of halved, and then halved again in the next block.
Specs:
Case: Coolermaster Haf 932
Power Supply: Corsair TX750
Motherboard: AsRock Extreme 7 Gen 3
CPU: Intel i7 2600k Overclocked to 4.9 Ghz
Ram: 16 gig G. Skill Sniper Low Voltage Series
Graphic Cards: 2 x XFX 5870's
Hard Drives: 1 Terabyte 5400 - 1.5 Terabyte 7200
SSD: OCZ Agility 3 120gb
Blu Ray: Asus Black
CPU Cooler: Rasa RS360 water cooling kit.
Max temp when running a game is about 54C
yah I'm probably going to put a 120 rad in the back. but thats far in the future
