TH Water Cooling Club and Picture Gallery
Page 9 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Your last thread is almost 90% ok, you need remove the
earl45- I also use Photobucket. If you look on the image page, there are 4 different URLs available on the right side. You want the one that says 'IMG code'. If you simply click it, the site 'copies' it to your clipboard...or simply highlight and copy/paste. This will be the format you need...and you don't need to add the extra tags.
Thanks! You can really tell from these better photos that I have a little touch-up to do, but all in all...I am very happy with how this turned out. I just wish it wasn't as heavy as it is, but I don't go to LAN's as much as I used to, so transporting isn't as big of an issue. If I were to do this again, I'd make sure I had a table saw and some different tools than what I used for this project. The entire thing was cut using a jigsaw and even though I took incredible care to make good cuts, human error is to blame for how some of the panels fit. I can fix the minor imperfections, and I worked quite a bit to get most to fit as they stand now. Would I do this again? Certainly- but only if I had as good or better plans than I did with this project. The hardest part is making sure everything fits together in three dimensions as well getting mount points, holes and all of those component placements that you take for granted when mounting gear inside of a normal case.
I wanted everything visible...I wanted it to be more art than anything. The HDDs, PSU, and wiring are all internal; I wanted the external/visible components to be very clean, functional and tidy, while lending to clean lines of the build. All the mess and garbage would be hidden, thus the reason all the other components are internal.
I was very, very close to mounting the HDDs externally to display them, but I had the 3x 5.25 bay mount for the drives, so I decided to stay with the black/white theme and mount them internally.
Hey all,
I'm nearly finished with my watercooling build. Just waiting on white single-braided cables for ATX and PCIE and a smaller res so it fits under my graphics card and I'll be finished.
Take a look and let me know what you think. Note: This picture was taken during leak test, so the observant eye might note the 24 pin is disconnected and jumpered.
Specs:
Fractal Design Arc Midi
/w modded window (not in picture)
AsRock Extreme4 Gen3
I5 2500K O/C @ 4.5ghz
w/ EK Supreme-HF Acetal block
Sapphire 7970 O/C @ 1125/1575
w/ EK FC7970 Acetal block
Antec 850w High Current Pro
Crucial M4 128gb
Seagate Baracuda 1TB 7200 rpm
G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 1600
EK D5 X-Res Top 140
w/ Alphacool VPP655
XSPC High Flex PVC Tubing - 3/8" ID (5/8"OD) - White
Black Ice GTX Xtreme 240 Rad
Black Ice SR 140 Rad
Bitspower 3/8" ID, 5/8" OD Compression Fittings
NZXT 24" sleaved LED - White
LITE-ON Black Internal 12X Blu-ray
Some 8x fan controller I can't remember the name to. lol
4x 140mm NZXT FN-140RB Rifle Fan (push/pull on 140 rad and front intake/rear exhaust)
4x 120mm Scythe Gentle Typhoon AP-15s (push/pull on 240 Rad) (only have 2 of these installed in the pic, but will put the other 2 in tonight)
Let me know what you think! Cheers :-D
Not sure why it wouldn't be enough rad, but here's some stats . . . cuz haterz gonna hate! 😛
The following was captured after running Unigine Heaven 2.5 and prime 95 blend test simultaneously for about an hour.
Temps stayed pretty constant. GPU never went over 40C and CPU stayed low to mid 50s for most of the run.
I'm gonna start gaming now and probably will all night. Can post temps when I'm done
2 hours of gaming later:
Max CPU temp: 52
Avg CPU temp: 43
Max GPU temp: 37
Avg GPU temp: 34
Mind you, it was only SWTOR which isn't all that intense, but I doubt I'd get much different results on BF3. If I can bring myself to play that game again, I'll let ya know.
