TH Water Cooling Club and Picture Gallery
Page 7 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
You didn't bug me at all. One of the great things with watercooling is the abundance of opportunities to help people. We're all here to help one another build rigs to the best of our potential.
Wow, someone liked my idea on how my HDD were mounted on my HDD Bay.
Also I saw your lapped job on the CPU, you need to work on it better though
I just love the overall design. I put my res and radiators outside of the case too, but I built mine last year before I seen urs. Love the dual reservoirs and the way you have them mounted. Looks great. 😀
Thanks guys
Spec is:
Core i7 2600K @ 5Ghz 1.523V (degradation kicking in)
3 x HD6950's flashed to HD6970's @ 940/1375 1.230V (Still testing)
4 x 2GB Corsair Dominator 1600Mhz 7-8-7-21 1T 1.65V
ASUS Workstation Revolution P8P67
NZXT Hale90 1000W Gold Certified
SilverStone Tj07 (Modded)
1TB Samsung Spinpoint F3
80GB OCZ Vertex 2 SSD
Gentle Typhon 1850rpm and Bitfenix Spectra 1000rpm Fans
External LG Blu-Ray Player
18W DDC 355 Pump
10W DDC 350 Pump
EK Supreme HF CPU Waterblock
3 x Heatkiller GPU-x3 HD69x0 Waterblock
120.4 Phoyba G-Changer V2 Black
120.3 XSPC RS
Bitspower, EK and Koolance Fittings
Mayhems "Oil Black" Coolant
Frozen Q "T-Virus" 150ml Res
Purple 1/2" Tubing
Lots of sleeving.
I wanted to make a build log called "how to fit 3 radiators in a mid tower", but I was too caught up in putting everything together that I forgot to take pictures. I even got a fancy new camera for the occasion (well, not specifically for that, but I got it earlier than I otherwise would have). haha
Looks awesome! Fitting another rad inside my 900 II is something I've often thought about, would be nice to see what hoops you had to jump through - although let's be honest, the 600T is a really big mid case 😉. It's way bigger than mine, anyway. I built a PC with one a couple weeks ago. Really, really liked the design.
New build 3930k @ 4.6 with 2x480 in the loop single 120x 240 rad heatkiller block
run s like a screemin deamon
http://www.youtube.com/watch?v=ekCcM0IKcv4&feature=player_detailpage
Edit 1: hers my rig http://www.flickr.com/photos/71446184@N08/6452454769/in/photostream
Edit 2: well try here
<a href="http://www.flickr.com/photos/71446184@N08/6452454769/" title="3930 2x480 2 by robustus64, on Flickr"><img src="http://farm8.staticflickr.com/7174/6452454769_ab266902c7_b.jpg" width="1024" height="768" alt="3930 2x480 2"></a>
Robustus64- FYI, there is an edit feature that allows you to make edits to your posts. No need to continually post in succession when you can modify and edit a single post to reflect updates.
Edit: That helps! It makes all your ideas for a single post well-defined and in a single location. Nice job.
