TH Water Cooling Club and Picture Gallery
Page 14 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
I just want the best of the best for my system, and I know all of the pro's hang out here 😉
Not really much point in a res from a performance standpoint, anyway. It does help with getting bubbles out, and it should help with filling the loop, but it doesn't affect temps. At least not by much. The volume just isn't that big unless you're using a big double bay res, but ultimately having appropriate cooling is significantly more important than a large water volume.
A simple T line for filling is all you need. Resevoirs are mostly for looks IMO.
Eh, you'd really be hard pressed to see much temp difference in an acrylic res, even in a single or dual bay res size. Water is moving so fast that it isn't spending much time there to be cooled. Also remember, plastics are very poor heat conductors so it's likely that any potential for heat dissipation is being hampered by acrylic's poor dissipation properties. There were some passive reservoirs in the past, but those were mainly made from aluminum...and we know where that conversation is headed.
My only point about double bay rads is the volume of water. Takes more energy to heat it up. Of course, running for a few hours and volume doesn't mean anything anymore. But for quick stress tests it might reduce the water temp a couple degrees.
Yes, overall volume will take a little longer to reach equilibrium, but when it comes to the volume of a single vs. a double bay res...I'm betting that difference is less than 1-2 minutes of difference and less than 1-2C during that time.
You could have a 5 gallon bucket as a reservoir and at 100% load, it would also reach working equilibrium, but it might actually be a bit less due to much larger surface area being able to dissipate heat.
Yeah, mostly for show, but they can help fill/bleed time if you have them setup in your loop correctly, i.e. feeding your pump inlet and level or higher to the inlet opening.
The wrong res can be a pain to use and other res's are just tacky.
I'm doing that on the radbox 🙂
When I'm done it'll be
Two EX480's push
One RX240 push/pull
Two X20 750 pump/resses
Two T-Virus resses
And five 120's in the case
Cooling a 975 at 4GHz
And the 6950's at standard clocks
Im only going push on the EX's for now, I'll add the other eight later 🙂
Moto
Heres is my newly plumbed loop...I shortened it quite a bit
Before:
After:
Keep in mind the fan, the 45º fitting should be more longer than others.
@wolfram23-->Thanks for the compliment...I am not a fan of windows or lights IMO it just looks gawdy, no offense just my opinion. I love keeping my inside nice and neat so when you do pop the side off at a LAN party people go...WOW !!!
