Unhandled Exception Errors What are they and How are they ..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi there and thanks
this error amongst many others with the unhandled exceptions errors are
really driving me nutty they couldnt come at more of a inconvient time
anyways im a gamer and some games it throws me this one as well as a few
others withh same sequence just diff #s and letters but here is one that i
wrote down Unhandled Exception:c0000005
at Address 46db6cFc
Can anyone Explain what that means and how it could be fixed any inputs
would be helpful
Thanks Yent
Hi Yent,
Unhandled_exception_errors are usually driver related. One or more device
drivers needs to be reinstalled or updated. 0xc0000005 is often related to a
Creative sound card, so if you are using one that is the first one I would
work on. Otherwise, you may be looking at a video problem as well. If a
minidump (.dmp file) is created when the error occurs, we may be able to
determine which file is the problem. You can send the .dmp file directly to
me at the address used here, use the subject line "per req" to get past the
filters.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Yent" <Yent@discussions.microsoft.com> wrote in message
news:CD6F9A3D-B6ED-45C4-8623-4FC709C0FECE@microsoft.com...
> Hi there and thanks
> at Address 46db6cFc
> would be helpful
> Thanks Yent
