I have:
Ryzen 5 1600
8gb Ram 3200hz
GTX 1060 3gb
1tb storage
Gigabyte AMD AB350-GAMING 3 AM4 socket ATX motherboard
My PC will turn on then load at the gigabyte loading screen, then just get stuck on the loop and eventually freeze then restart the PC and repeat. This happened a month ago, I then tried reinstalling windows which it worked but all the graphics were messed up and then returned to this problem, so I no longer thought it was the hard drive but the graphics card - I had got caught up and wasnt able to try fix my PC again.
Now a month later I turn it on, and everything is fine for an hour or so - I was glad it was working and checked everything out, and it seemed to be fine (all the components). Then randomly again, it returned to the problem of the PC restarting by itself, and freezing at the gigabyte loading screen.
Any help would be greatly appreciated, I had spent over £700.
Ryzen 5 1600
8gb Ram 3200hz
GTX 1060 3gb
1tb storage
