Okay so I'm in a really big bind right now. So i just went home on Monday to grab a 240mm case fan and a couple 120mm i installed my 240mm and two 120mm into my build and immediately none of them booted so i removed the two 120mm fans in doing so i accidentally removed my cmos jumper and tried running my cpu easily a dozen times after i saw the cmos jumper was off i immediately put it back. Following this my computer has been stuck in a boot loop but it won't send power to anything but the internal parts of my build everything will light up the fans will run ill hear it hum and beep but nothing else and then it powers down and cycles again. I'm freaking out hardcore over this thing because this is my third time rebuilding it and i don't have the mo ey to buy anything else for it right now.
So far i have
My builds
A Ryzen 3 1200X
16gb patriot viper RAM
ASRock Ab350 pro4 motherboard
Evega 550w power supply
500 gb Wd hdd
1tb samsung hdd
250 gb Samsung ssd
Nvidia GTX 1050
An asus lan wifi adapter
Toshiba cd drive
In the thermaltake versa 21
I seriously need help guys
So far i have
- Reset the CMOS
- Re fitted the RAM
- Run with only one stick
- Remove CMOS battery for 12 hours and allow it to reset and re apply
- Re fit the pcie cable
- Removed and re set the graphics card
- Removed the power line and put it back
- Re fitted the hdd drives
My builds
A Ryzen 3 1200X
500 gb Wd hdd
1tb samsung hdd
250 gb Samsung ssd
Nvidia GTX 1050
Toshiba cd drive
