https://skydrive.live.com/redir?resid=8F38B87E1779DB5!1568&authkey=!ABdTM-otUO8zCz4c5244714@gmail.com
Hello all
I have a little complex network problem with switches layer two which install in ring topology
The sketch and the specific scenario is described in the link file
now each port is member and tagged to its VLAN
for example : switch 19- ports 11-12 tagged member of VLAN5 default: VLAN5, ports 9-10 tagged
,member of VLAN 4 , default VLAN 4 and so on.
I had suggested to add the link ports (9-12) to be a member of all VLAN configure in its switch
For example: switch 19:
Ports 9,10,11,12 will be a member of VLANs 4 and VLAN5,And so on for the rest of the switches
The problem for example is that in VLAN3 two ports (11 in switch 1 and 11 in switch 6) are both in DISCARDING
so it is not OK for ring topology when I expected to get only one DISCARDING port for each ring .
(communication is not possible between vlan6 to vlan 1 when i unplugged port 12 in switch 3)
What is the correct configuration per switch to make it works ?
please describe in details
many thanks for your comment
Hello all
