EDIT 2: ok after some research, i found out that regardless of the situation, the R7 would always be used since the display's only connected to the APU, however, during intensive task like games, the RX 460 supposedly would "come and help" with the rendering task [basically, it's not "switchable graphic", it's more of an "add-on graphic"], however, this still doesn't explain the low fps and weird stats on the task manager, and also the fact that games still runs horribly, regardless of the settings
CSGO: ~10-50 fps (depends on what happened) during the freeze time it's usually around 60-70, as the game starts, FPS would start to decline too
Dota 2: 10-32 fps (regardless of setting, I ran it on DX11) starts out on 60-70, as the game progresses, the FPS declines
Far Cry 5: 8-19 fps (and 0.97 VRAM usage) FPS just plain tanks out during the whole benchmark
as bad as this FX-9830p + RX 460 combo is, I doubt that it's supposed to perform worse than an i5 4200u + R5 M335 combo (coz that's what my friends had and he ran games way smoother than my laptop did) or even a G850 + GT630 (my old rig) for that matter...
TL;DR: very low fps and unstable overall performance, despite the hardware that it packs, many reviews shows how this laptop supposedly able to at least play AAA titles on low-med, well I'd say FC5 with 12 avg FPS on the lowest setting is not by all means, PLAYABLE...
here's the gist:
i hope one of you guys have encountered this problem and/or know the solution to this problem
Laptop specs: F X550IU
FX-9830p
16 GB DDR4 2133mhz
1 TB 5400 RPM
R7 Graphic (1GB VRAM)
RX 460 (supposedly 4GB VRAM according to Radeon driver and GPU-Z) listed as 1GB in games and Task Manager
Things I've tried (and doesn't seem to solve the problem):
1 reinstalling driver
2 DDU and then reinstalling the driver again
3disabling integrated GPU the display's only connected to the APU so disabling it = no graphic card at all [stuck with window's basic adapter basically]
4 update the driver from Device Manager
5 switching every possible switch to high performance (power plan and switchable graphics settings)
6 Installing driver from ASUS's website
EDIT 1:
1) shows how the RX 460 only had 1 GB of VRAM at its disposal
View: https://imgur.com/a/Gz6zlcj
2) the real spec of the RX 460, clearly listed 4GB GDDR5
View: https://imgur.com/a/f6tgP0U
EDIT 3:
3) FC5 benchmark result
View: https://i.imgur.com/veITReMh.jpg
here's the gist:
- I tried to run CSGO, noticed low fps overall and highly erratic fps drop
- I tried finding the cause, notice that the RX 460 on Task Manager's Performance Tab only had 1GB of VRAM
- I confirmed that's the case in MSI Afterburner since, on that app, the only VRAM stat that exists belongs to the GPU7 (which is the integrated R7's VRAM)
- I mean, yeah the GPU would probably also throttle and the CPU is holding it back, but I mean, come on, fps drop to the single digit on CSGO regardless of the setting? something weird's definitely happening
- also, RX 460 usage seems to be pretty sporadic too, spiking up and down
FX-9830p
16 GB DDR4 2133mhz
1 TB 5400 RPM
EDIT 1:
EDIT 3:
