OrdJk Reputable Jul 26, 2019 231 6 4,595 Aug 17, 2020 #1 My budget is like £40-60 ($50) and I need to power my microphone with that money. I don't have much experience with phantom power and I wanted to get some advice here
Solution hang-the-9 Aug 18, 2020 Anything with a phantom power XLR connection will work but for your budget you need to look at used products. Anything cheap does not work well. https://focusrite.com/en/ios-audio-interface/itrack/itrack-solo https://www.amazon.com/dp/B071W6YVD...42ad36e35f89f861a714eb168&language=en_US&th=1
OrdJk Reputable Jul 26, 2019 231 6 4,595 Aug 17, 2020 #2 I am quite new to this whole "condenser" microphone stuff and I really need a guide to setting up a MXL 770 microphone into a PC. I have a budget of about £40-70 for the rest of the stuff for the microphone. Any help would truly be appreciated Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Aug 18, 2020 Solution #3 Anything with a phantom power XLR connection will work but for your budget you need to look at used products. Anything cheap does not work well. https://focusrite.com/en/ios-audio-interface/itrack/itrack-solo https://www.amazon.com/dp/B071W6YVD...42ad36e35f89f861a714eb168&language=en_US&th=1 Upvote 1 Downvote Solution
