Where do you see that there is anything wrong? For the hardware you have, as compared to other identical hardware, you are in the 85th percentile on GPU and 89th percentile on the CPU. That's not terrible at all to be honest. And furthermore, userbenchmark is a pile of crap anyhow. As often mentioned here, it hates if you have anything else running, so it's usually a good idea to shut down, restart, go to the site, wait about five minutes for things to calm down and initial processes to complete their startup routines, make sure no other applications are running and then run it again.
But overall, I've not seeing a problem there really. The only reason you are likely even down into the 80-90th percentile range compared to other users...
