[SOLVED] What should I do for keeping my system colder
mmd_jvd
73
Hi there,
So im changing my cpu from core i3 9100f to core i5 9400f!
Here's some questions...
I'm worried about my coolness!
I mean already my case has only one usual air cooling fan and my cpu temp is not bad... I use from its maximum power tho! Cuz i work with after effects
I just wanted to ask while my case have only one fan, the default fan of 9400f can keep it cool? I mean i am not like those ppl keeping their pc temp very down so they could show off or whatever, until there's no hurt on my cpu I'm fine!
I can't buy a water cooling system or an expensive air Cooling fan
I only can buy deep cool Alta 7
Either u rather buying that instead of the default cpu fan?
Or using cpu default fan and adding some fans to my case?!
Which one do u offer?!
Already config is core i3 9100f. 1060 6GB 256 ssd. 1tr hdd 7200rpm. 2x 8gb ddr4 2400 ram and in rendering cpu temp is like 75
I would appreciate that if u suggest me every other ways too for making my new cpu cooler
It's some images from my case
https://www.ebpnovin.com/کیس-کامپیوتر-گرین-green-magnum-plus
