Hi, I am a video editor. I use After Effects and Premiere Pro a lot. I recently I built my first PC! These are the specs:
CPU: i9 990k
CPU COOLER: NZXT Kraken X72
MOTHERBOARD: Asus Z390-E
RAM: 32 GB GSKILL 3200 MHZ Trident-Z RGB
GPU: Asus RTX 2080 Strix OC
STORAGE: Samsung 970 EVO Plus 500 gb M.2, Samsung 870 1TB SSD, Seagate Barracuda 4TB HDD
CASE: NZXT H700i
PSU: Corsair Hx 750 Platinum PSU
I am running the 360mm Rad in the top of the H700i case with all three fans as exhaust. I have 3 intake fans on the front, and one last 140mm fan as exhaust on the back.
(I feel like my fan configuration is leading to higher temps)
The AIO is seated correctly (or so i think, i tried tightening an all the screws again and they are making contact correctly)
With this PC I want to overclock to a steady 5GHZ so my rendering speeds are super fast.
Currently the i9 9900k is running at 4.7 GHZ
CPU: i9 990k
CASE: NZXT H700i
