[SOLVED] Which System Cooling Fans Should I Buy?
Aug 7, 2020
37
What are some decent & budget RGB cooling fans from this store --> https://www.simarksupplies.com/Product.aspx/Category/C28-Cooling
I will be buying 6 of the same fans to fill up my Corsair Crystal 460X Case ( Non-RGB Standard Version )
The fan mount locations:
Front: (x3) 120mm or (x2) 140mm
Top: (x2) 120/140mm
Rear:
(x1) 120mm
If none of the fans in that store are good, my other option would be to buy 6 Corsair SP120 PRO RGB Fans + a Corsair Lighting Node PRO Lighting Controller, which will cost me more than double the case itself ;-; ( fans + controller = around 240 euros... the case is 115 euros )
Thank you :) !
