This is a weird problem. I have no issues whatsoever with either my internet connection or speed. My download speeds haven't changed, they're more or less at the speed my router locks at about 1,5 MB/s (I should have a nominal DSL speed of 3 MB/s, but, you know...ISPs).
However, when I look at the icon that has a summary of my connection, it detects the speed as being 13,9 KB/s almost an ISDN speed. I wouldn't have a problem with that, but ever since that happened, I can't seem to connect to a TF2 server for more than 20-30 seconds (with the rare exception). I get disconnected almost immediately. Sometimes, I can't even connect at all. I don't know if the two problems are connected, but it's worth putting it here. Oh, and I think my problem started when I was trying to see if I can disconnect the pc from the internet by clicking on "disconnect". It turned out I can.
My specs:
Windows XP Home
Wireless Router Thomson 585g (I think - however it has a wired connection to my pc)
Other specs shouldn't matter but here they go: Core 2 Duo E6400, 2GB RAM, P5B Asus mobo
So, is there a problem here? Are the TF2 problem and the false speed detection connected? Can I do anything about it?
Thanks in advance.
My specs:
Windows XP Home
Thanks in advance.
