Question Will a 3-pin RGB fan work in a 4-pin RGB header?
Well then couldn’t you just plug it into the 3 pin header? I’m having the same problem just different case/motherboard.
I'm not sure since a 4-pin RGB header is 12V and a 3-pin RGB header is 5V therefore the fan's 3-pin RGB is 5V. I'm not sure. This is the first time I meddling with RGB.
