[SOLVED] Will my current PSU be okay if I ever upgrade CPU & GPU?
Jamry
59
Current specs at the moment:
R7 1700 (Upgrading to R5 5600x)
16GB Ram
Sapphire Nitro+ 8 GB RX 570 (Still not decided, though I am leaning towards RX 6600 XT/RTX 2070 Super)
Seasonic M12II Evo 520w
Many thanks!
I'd personally be uneasy with it given the way newer Ryzen processors aggressively boost their power, but it's not likely to be actually dangerous; it's an archaic, inappropriate design to be using with modern equipment, but given the manufacturer, it's a well-made archaic, inappropriate design.
The proposed upgrade would be just fine.
16GB Ram
Many thanks!
It's a really old design and group-regulated, so it's not really all that good right now, let alone with newer, more power-hungry parts.
Reactions: Jamry
Reactions: Jamry
Thank you sir, might as well upgrade my PSU before putting the CPU in. Better be safe than not!
EDIT: Wording
