Question Will plastic chassis of Gigabyte G5 MF cause overheat problems?
ChrisTsall99
702
I am searching for a gaming laptop and I found the following:
Gigabyte G5 MF
It has plastic chassis and I would like to ask, will it cause any overheating problems ? Should I look for another laptop with aluminum chassis ? I don’t want performance drop while gaming, cause of overheat.
Specs:
Intel Core i5 12500H
GeForce RTX 4050 6GB
8GB DDR4 3200Mhz
512GB SSD
I don't think an aluminum chassis will help much with gaming performance.
A gaming laptop need a high-performant cooling system (dual fans, large copper tubes and vent...)
And the ambient temperature is the most important factor, if your room has the A/C on, the laptop will perform better.
I found ASUS TUF Gaming FX506HC-HN004 (for the same price), which has aluminum chassis, but a lower-end GPU (RTX 3050). Based on what you are saying, I could go for the Gigabyte G5, right ?
@NanoSuit3
@lvt
@NanoSuit3
@lvt
Sure, you should focus on the technical specs rather than the chassis material.
Laptop chassis is usually made from high-density plastic and it's very durable. Aluminum is mainly used for making the laptop thinner while retaining the structure's robustness. Aluminum is used as a passive cooling solution by some laptop models, but if you are a performant user, you need a laptop with good active cooling system.
