Hi Guys, this is a very specific issue I am having with getting stable wireless connection from my built PC - hopefully someone with technical knowledge can help me out with this.
Before getting in to it, I thought I would just mention that I have a custom built PC as I believe this is a huge contributing factor.
Anyhow, my PC has issues using wireless adapters when it comes to online gaming and web browsing. 90% of the time it works fine, however the connection will drop when entering online games or loading up web pages but mainly during the former. The web page or game will disconnect, the wireless symbol on the bottom right of the task bar will show the icon with a yellow warning triangle for around a minute, then connect again as normal or disconnect entirely, register the USB again (as if being plugged in again) and then reconnect. I am no expert but maybe it is to do with a high volume of information being sent and received (?).
This is definitely nothing to do with the dongle itself. I have tried three different dongles in the past and still had the same problems and i have played around with the device settings in the control panel e.g. power saving, different channels, selective suspend etc. for each dongle and nothing has helped. This leads me to believe there is an issue with the hardware inside my PC.
I also do not believe it has anything to do with the placement of the router or my PC in my home. My partner has their desk adjacent to mine and does not experience the same issues as me.
I also have a PCIe wireless card which does not drop the connection. Though, the speeds are much worse using this. Gaming using the card becomes a problem as ping fluctuates and makes for an unplayable experience.
My thoughts are that it could be the motherboard but I have no idea. I think I have included all helpful info but feel free to ask more questions.
I am really just looking for a clue to find out why this is happening and what steps I can take to fix it.
A huge thanks in advance,
MisterG
MisterG
