Hey guys,
I'm fortunate enough to be able to work from home now, and just set up my desktop at home beside my gaming pc.
I ran into a problem, ethernet is ran and plugged in, I verified the cable works fine but I can get internet on my work pc. It keeps giving me the error of "Ethernet doesn't have a valid IP configuration"
The cable is run to a ethernet switch in my hall, it has my mothers work laptop, and my gaming pc hooked up to it and we've had no problems whatsoever so far.
I'm thinking it's the switch that is causing the problem, but I don't have any other way to hook it up without causing problems. I was hoping that there'd be a quick fix like configuring the switch or something.
(Currently running windows 10)
Any advice would be greatly appreciated!
Thank you in advance
This is the switch;
https://www.newegg.ca/d-link-dgs-105-5-x-rj45/p/N82E16817111038?item=N82E16817111038&source=region&nm_mc=knc-googleadwordsca-pc&cm_mmc=knc-googleadwordsca-pc-_-pla-_-network+-+switches-_-N82E16817111038&gclid=CjwKCAiAgJWABhArEiwAmNVTB03DyfM91OpoHI-NGWsldajhamz91ZaVaxjkHgwCDcqR3W_zjdAbwxoC39MQAvD_BwE
This is the switch;
