Hey there,
I've had a problem 2 days ago with my Mainboard - ASUS Z270F Gaming. I heard a spark somewhere, the system turned off and since then I haven't been able to boot it. I've been deconstructing it the last days step by step to search for any errors and at this point I think it's either the Mainboard or the CPU.
Spark came from the PSU - probably from an exposed wire while the System was not powered on had power runnin through it.
specs:
built: 2016
What I've done:
When I plug in my old AX860i to my motherboard the PWR_LED [1] lights up constantly and powers the mainboard (I can feel warmth coming of from it) and the RGB lights also light up.
Although when I plug it with the brand new SF600 from Corsair I only get a blinking PWR_LED [1], with no RGB lights on the MOBO as well as no signs of power running through the Mainboard
Like I said, both are tested with a Multimeter and display the right voltages and are able to run with the paperclip test.
I'm open for anything right now as I did everything I was able to find online and test out and read a lot of different forum guides for any possible fixes.
Maybe I need to bite it up an accept that it's dead, I appreciate any tips for maybe getting it to start. -> Anything <-
Thanks in advance!
specs:
built: 2016
- i7 7700K
- Asus Z270F Gaming
- Corsair AX860i and a brand new SF600 iI got for testing
- Corsair 16GB 2 stick, worked well before
- rest doesn't matter I think, I got the barebones Mainboard with the CPU/RAM and PSU sitting on my table,
[1] Standby Power LED (signaling that power is running) | [2] Boot debug lights for the different stages | [3] Front panel input |
What I've done:
- this guide https://forums.tomshardware.com/thr...put-troubleshooting-checklist.1285536/(mostly, from what I was available to do, although I have no Beeper)
- Clear CMOS
- checked CPU pins - not bent!
- reposition CPU/RAM and about every PSU cable I have (they're both modular)
- firmly attach the 24pin ATX and 8 pin cpu cable, multiple times
- Test both PSU 24pin ATX and 8 pin cpu with a Multimeter, voltages are fine, both power up fine and powered the rest of my setup (HDDS/SSDS/Fans/Leds etc.)
- PWRSW switched on with my Case / jumping them doesn't work, tested with both PSU's [3]
- connected PWM fan to CPU_FAN to exclude it not starting up because of cooling
- single stick ram, double stick ram, no ram
Thanks in advance!
