Havin 100Tx problems with network!
Most machines on the LinkSys 8 port router/switch will autosense and run 100Tx full dup. Have a problem child that won't. Have to manually set it back to 10X full dup. Thought it might be the cheap WinBond 10/100 Nic. Changed it to a LinkSys Tx100 like others on the LAN. Opps, still no 100tx. Now where's the problem?
Cableing? If I put the box upstairs closer to the hub I can get 100Tx. Put it on a longer run downstairs no 100Tx, but 10 OK... Cabling is Cat5 pulled thru conduit - a problem to redo. Isn't Cat5/100tx supposed to be able to go like 300meters. This shot's only like 110-125 ft.
What's restricting the line speed to 10X?. Doesn't seam to be the workstation.
