Hello,
So i have a problem with my monitor which is Asus VG248QE, the display does not feel smooth at all. It actually feels just the same as the old one which was a random cheap 60hz monitor. I have changed my Windows settings to 144hz and also nVidia Control Panel settings are set to 144hz and improved performance.
My hardware specs are:
AMD Ryzen 5 3600X
16gb RAM 2667mhz
MSI B450 Tomahawk MAX
nVidia geforce 1660super
monitor: Asus VG248QE (display port cable)
Basicaly my problem is that when im playing videogames such as League of Legends, my frames are dropping and the game does not feel smooth. I used to have my settings set to everything low and for imrpoved performance but lately I found out that it's actually better if my settings are on high not sure whats the logic behind that? So my ingame settings are now set to high and Windows settings are set to 144hz and nVidia control panel settings are set to imrpoved performance, but the game still feels like some fps are skipping. I would kindly ask you if anyone can help me.
vertical sync is off...
Greetings
AMD Ryzen 5 3600X
16gb RAM 2667mhz
Greetings
