Question 4 fans on an asrock z370 extreme4?
colbs2411
57
Hello all,
As the question says, I am looking to run 4 fans on an asrock Z370 extreme4, which from what I can see in the bios can only run three.
I am currently running the stock fans from the fractal meshify c - which I know aren't great - so I was looking to get some be quiet BL065 silent wings 3 fans for intake and then run the stock fans as exhaust.
Is there a safe and easy way to manage this on this motherboard? Don't want to end up burning out a header or something like that.
my build can be found here (https://pcpartpicker.com/user/Colbs2411/saved/#view=L6ccYJ)
The fans I have are 3 pin and the ones on sale were too, as I can control their speeds with the as rock utility so save money on pmw. Would you be able to link to the phanteks, or would any such device work? Some are quite expensive and others are more affordable, and given I only want to use the connector to connect the fans (not regulate them) then would this still work? Sorry, not all that familiar with fan controllers
