I have a 42" Panasonic TCP42S1 Plasma TV. I want to use it for gaming. Come to find out it have a refresh rate of only 60hz... Plasmas dont need to have as high of refresh rates like LCD's but they marketed it as having 600hz. The 600Hz Sub-field Drive anti-blur technology is what is has and im wondering how this will affect gaming on the tv and the FPS it can display. This is the anti-blur tech. explained...
http://www.tvlampsnbulbs.com/2009/03/what-does-600hz-subfield-motion-mean/
"For each frame displayed on the TV the Sub-field drive flashes the dots 10 times or more, meaning that the dots are flashing 600 times per second (600Hz) or more. (Example: 60 frames per second x 10 sub-fields = 600 flashes per second)."
"It all boils down to TV manufacturers using some science to trick our eyes into perceiving a better picture. The television shows you the image at the same refresh rate but fires the individual pixels faster so the images appear smoother."
Anyone who games with a plasma tv let me know how they handle higher fps, 60+?
Im looking at either using GTX 570 or 560 ti Sli for my first build in the next couple of weeks.....
