Question After installing Windows 11, stuck on VGA LED after shutdown or reboot, but turning it off and on makes it work!?
Whenever my PC turns on (either from being powered off or from rebooting) it gets stuck in the VGA LED light from my Motherboard. I then have to press the power on button twice manually for it to actually post and boot onto Windows, where all works perfectly fine.
This has happened since I updated my BIOS to the newest version (MSI MPG x570 Gaming Plus - Bios version: 7C37vAH) to be able to upgrade to Windows 11. Used the installation tool to manually install Windows 11 since the PC Health Check said my system met the requirements but I wasn't able to update through Windows Update.
I've tried disabling Fast Boot, but that didn't help either...
Any ideas?
Reactions: somesh101
full system spec? include brand and model of the psu
I don't see how that info would help, since it's a problem that has been occurring since I changed the software, not the hardware, but here you go:
-Ryzen 3700x
-MSI MPG x570 Gaming Plus
-64 GB Corsair Vengeance LPX 3200Mhz
-Gigabyte Nvidia 2070 Super
-Nox Urano VX 750W
I have similar issue. The system hangs when i click the shutdow/restart/ turn on.
i am forced to make a hard shutdown using the main power or by holding down CPU main Button.
So far no idea why is that happening.
