Hi everyone,
decided to treat myself to an upgrade and plucked for a i7-9700K and an ASUS Z-390 P Prime.
On first start up the CPU temp was already at 65C when I entered the BIOS and it kept climbing until 75C when I switched it off. BIOS isn’t recognising the AIO or CPU_Fan connections.
Voltage hovers between 1.012 to 1.21. I have remounted the AIO cooler using the pea method and thermal grizzly paste.
parts list all running stock:
i7-9700K
Asus Z-390P Prime
32Gb Corsair Vengeance LPX DDR4 3200Mhz (4x 8Gb sticks)
Corsair RM650X (80 Plus Gold)
Asus GeForce DUAL GTX 1060 6Gb DDR5
Corsair H100i v2
All I can think of is the H100i is dead but I’m hoping you guys could suggest something that I’ve overlooked, this is only my second build.
previous build was i5-7600K and Z-270 Prime, the BIOS not picking up the CPU Fan was present on that build however the temps at idle were 27C with the same cooler.
In this image the case fans are disconnected, for some reason on this attempt it started off at 35C and again rose to 75C before I switched it off. Ambient temperature is cool in this room, radiators are switched off specifically to keep it cool.
i7-9700K
Asus Z-390P Prime
Corsair H100i v2
