[SOLVED] Best way to hook up old HD's to a PC.
JUDGE DREDD2013
26
Can someone give advice on the best way to hook up some old PC Hard Drives to a PC?
I found four old HD's in a drawer and I would like to see if there is anything on them. Three have the old type of pin connector and one a SATA connector. I am running Windows Ten Pro 64.
I was thinking of a cable or something rather than a enclosure.
Thanks
If you just want to check, what's on those drives, then use external USB adapter for connecting sata/pata drives.
If you want to actually use those drives on a desktop pc, then ...
For SATA drive - use sata data and sata power cables to connect it to a desktop pc.
For PATA drive - get PCIE PATA controller card and connect drive using pata cable and molex power plug.
Reactions: rgd1101
Thanks
You should dump them all but the SATA.
The IDE HDD has max transfer rate of 133MB/s while the lowest SATA has 300MB/s.
If you have USB 3.0, you can buy this adapter for your SATA HDD. It comes with a 12V wall adapter for the power.
