Hi i need help i am wondering if i should buy a new fan cooler or if there is some other solution to my problem. I recently bought a 3070 ti and on 1080p on destiny 2 and other games i only get about 100 frames because my ryzen 7 2700x is only running at 30-40% on task manager and on ryzen master the temperatures are around 75-85 Celsius i am currently using the stock ryzen cooler and am wondering if the cooler could be the problem causing it to bottleneck because it gets too hot or if there is some other fix.
