[SOLVED] Can an HP Compaq Pro 6200 SFF handle a PNY GeForce GTX 750 Ti 2gb OC card?
That's actually a low end choice for that. You might see if you can find a GTX1050 series that fits. They come in 2GB and 4GB versions.
I don't recommend 4GB video cards for 8GB systems. They work OK "most of" the time, but if you have 12GB or more RAM it's better.
The 1050 ti lp oc by msi is great for sff applications--just make sure you can handle a double height card--I know my Dell 3020 sff can't. 🙁
And I know where there is an open box one for $108+shipping that will have a full factory warranty if you're in the US. PM me and I'll send you the link. :)
