Motopsychojdn :
I think it may have been mentioned further up and my brains just caught on,
I'll feed the graphics cards to the rads, not the chillerbox, let the fans cool the water before it hits the chiller and I should see lower temps
Moto
Learned the hard way:
Radiator Cooling is always on the plus ambient side, no matter how many radiators there are.
Radiator plus Chilled water will yield close to actual ambient, but the radiator tends to warm the chilled water because it operates in ambient.
Chilled Water produces below ambient, how far below ambient depends on how you are chilling it.
Thoughts about using a radiator to drop the water temperature before going to the chillbox seem to be a good idea, I thought it was, but it became the opposite of what I wanted as it kept the chilled water from going as low as I wanted.
Because the chilled water is circulated back through the radiator, don't forget how a radiator is actually used in a car, 2 different radiator principles are used.
The main radiator cools the engine, the secondary heater core radiator heats the inside of the car, the reason I brought that up was to consider the uses of radiators before they were ever modified for use in the computer water cooling.
The radiator itself is not an active cooling component, the water flows through it period and it's only means to affect the waters temperature is the air flowing through the cooling fins.
If the air in the room is cooler than the water flowing through the radiator it cools, if the air in the room is hotter than the water flowing through the radiator it heats.
The whole purpose of the chillbox is to give you below ambient water to cool with, and combinations with radiators will negate that goal.
If you go that route, you will discover exactly the same results as I did.
